aren't going to bother writting another one. Can be found in the same
location as the maint manual.
Sent: Saturday, June 26, 2004 9:37 AM
Subject: RE: Smacking it on the runway!!
Not a word as of sun n fun
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
David Ricker
Sent: Saturday, June 26, 2004 9:14 AM
Subject: Re: Smacking it on the runway!!
Keith
Have you heard of the existence of an Elite POH? Last time I asked it
didn't seem to exist.
Dave R.
www.elite583.cjb.net
Keith Oliver wrote:
--Thanks
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
WALTER KLATT
Sent: Friday, June 25, 2004 5:36 PM
Subject: Re: RE: Smacking it on the runway!!
You can download the latest manuals from this link.
http://www.murphyair.com/SUPPORT/Rebel.htm
Date: Friday, June 25, 2004 2:15 pm
-----------------------------------------------------200 hour "throw away" in
their Maintenance Manual.... WHAT MANUAL
Keith Oliver
Elite #654 TD
N654ME (reserved)
Farmingdale, Maine
From: mike.davis@dcsol.com [mike.davis@dcsol.com]On Behalf Of
Sent: Thursday, June 24, 2004 10:18 PM
I've been sitting back on this one Frank..... as I don't like to
over sell
here.... but the weakest link of the gear is that aluminum bungee
strut.Even MAM has it (the slider section) down now as a 200 hour
"throw away" in
their Maintenance Manual.... so they started listening somewhere
along the
line. The best "Band-Aid" you can use to hold the legs together is
the 4130
struts and die springs like I build, or that you can fabricate
yourself.
These overbuilt 4130 struts do wonders for keeping the gear intact
even in a
ground loop. I've done one intentionally to avoid going through a
fence (at
about 35 MPH) and have watched a "customer" do a couple at 45MPH++
withoutdamage to airframe. The only thing I have managed to bend
on my airplane is
a main gear leg and I had to do a helicopter landing (at about 3
g's) onto
one ski edge, that sheared all my door post rivets out, broke my
windshieldetc. The bent leg was very hard to detect even off the
airplane. All I
noticed to prompt removing it was the tire/wheel seemed to sit a
littlecocked compared to usual. Placing the gear leg on a flat
surface and holding
at one end barely showed the warp, but pushing down at the other
end had the
opposite end about an inch in the air thanks to the bend being
only a few
inches out from the one end.
First check your bungee bolts. Did they get bent?? Then check the
main gear
leg with a steel straight edge that matches the full length of the
leg.
Sent: Sunday, June 20, 2004 7:57 PM
Subject: Smacking it on the runway!!
some great questionthat 138 have
been My question
is, don't feed
the anyone know
where probably over- somethingcan
List archives located at:
David A. Ricker
Fall River, Nova Scotia
Canada
