prop:
http://www.hartzellprop.com/kitplane/ki ... manufactur
er=Murphy%20SR2500
Maybe I just need to change the front wheels from 8.5" to larger <grin>
Ted
Sent: Monday, May 24, 2004 6:28 PM
Subject: Re: Tailwheel / prop clearance
Hi Ted !
92 " sounds like a lot for a 3 blade on the Moose -
is that the diameter that Hartzell recommends ?? I seem to recall that
the 2 blade paddle was 9 feet - 108". Would have thought that a 3 blade
would be a lot shorter ...
In any case, there wasn't a big problem with clearance with the 9 ft.
paddle - although I was a bit nervous about raising the tail
too far the first few times ! ;-) So you should be fine with a
larger tailwheel.
----------------------------orig.-------------------
On Monday 24 May 2004 07:54 pm, you wrote:
18" is for a Moose, 92" Hartzell 3-blade prop, stopped on the ground
with the std MAM tailwheel. I'm just thinking of how the prop
clearance is reduced during takeoff (pushing the tail up a bit as one
gets going) and during any sort of a wheel landing. A hangar mate has
*-----------------------------------------------------------------------a 185 with a 3-blade and his prop clearance was (I think) 24" (or
more).
Ted
Legeorgen@aol.com
Sent: Monday, May 24, 2004 5:47 PM
Ted,
Rebel or a Moose? 18" sounds like a lot even for a Moose. Did you
measure it in a flight level attitude?
I have a Rebel 0320 with a Scott 3200 tailwheel and It handles very
well. I never even unwrapped the MAM tailwheel form its plastic.
Bruce
