Empty weight for 1800 amphibs
Post by Bob Patterson » Sat Feb 18, 2012 9:00 am
Hi Bruce !
Probably pretty typical - I've personally never seen an
Elite that weighed under 1,100 lb. ....
Still loving my Rebel !
----------------------------orig.-------------------
On Wednesday 25 February 2004 11:43 pm, you wrote:
I knew the Elites were heavier but 1120 LB. Wow! That's a lot of extra
weight
for only 20 more HP to pull around. Was that a heavy Elite or is that
typical?
Bruce
Bob Fisher
Post by Bob Fisher » Sat Feb 18, 2012 9:00 am
hi angus does that weight included the spreader bars, rigging etc? bob
fisher
Sent: Thursday, February 26, 2004 11:17 AM
Subject: Re: Empty weight for 1800 amphibs
We are just ready to bring the front end loader into the hanger and push
floats under the Rebel,just kidding but we are using the loader to lift
plane.These are a set of MAM's earliest amphib kits and were built by Carm
Titus and used by him for about three years, they weigh 301#s.Yesterday I
completed the new 3.5"dia.x7"high cylindrical aluminum oil tank and it's
mounting pedestal which is affixed to the rear of the pump pedestal
between
the seats,also determined to mount the selector switch and pressure gauge
under the dash on the extreme left side.Perhaps we will do pictures to
post.
In case anyone is interested Clamar floats offer a Parker pump/selector
valve assy. which is quite small,maybe 3"square and 5high with a socket
for
a detachable handle,it is really neat and would consolidate the two
functions, it is also a lot of money.
I have faired bungee gear,12-9044 loops with MAM wheels 8:50x6 McCreary's
and a Scott 3200,steel spring. When we weigh all of this stuff I will
report.
A local scale company is available with certified digital platform scales
varying capacities which they deliver and operate and provide a federally
certified endorsed print out of the weight.
Another local aerial spray company has really cool and very expensive low
profile inter-connected digital platform scales to do their M-18 Dromaders
but they are more expensive to obtain the use of.
Regards, Angus
Sent: Wednesday, February 25, 2004 7:46 PM
Hi Bruce !
As far as I know, the Murphy brochure WAS based on a standard-gear
Rebel, so you're right - a smaller weight increase ! Although, the
spring gear Rebel would be likely about 20 lb. heavier to start with,
than a standard gear, because of all those doubler/trippler/octupler (!)
plates ... ;-) :-)
Just curious - how much do just the gear legs alone weigh ??
Axles, wheels, & tires would be the same on both gears, so the legs
would be the only difference. Anybody know what just the standard
gear legs weigh ?? I bet there's not a lot of difference, if you
count in the center tubes & the bungees (or die springs) ....
suspect most of the weight increase is in the fuse beef-ups.
I <LOVE> Warren's answer !!! :-) Get a good accountant
(maybe ex-Enron ??) to find you a set of scales that give you
the answer you want !! ;-) :-) :-)
On Wednesday 25 February 2004 08:14 pm, you wrote:
Bobp
Is that a net 253 LB. Increase for a standard gear Rebel? Because if
it
is,
that would mean a spring gear Rebel should have a smaller net increase
as
he is
removing gear that weighs more than the stock gear and then adding
back
same in floats.
Bruce
Angus McKenzie
Post by Angus McKenzie » Sat Feb 18, 2012 9:00 am
Hi Bob
301#s includes everything on the exterior of the aircraft including mounting
bolts and hydraulic oil line residue as they were removed from Carms
Rebel.My only interior components are : pump,tank,gauge/valve with their
mounts and interior tubing-all not yet weighed.
At Curtis Martins suggestion I relocated the tank at the pump to eliminate
interior tubing and associated mess. This created some extra work because I
had made and clecoed in a snazzy mount back in the left side fus for the
plastic MAM tank and had run grometted 3/8 stainless tubing under floor
through the bulkheads back to front............Angus
Bob Fisher
hi angus i weighed my floats today
all the rigging came in at 41 lbs the pump, tank and valve at 7lbs with
the tank 3/4 full
the floats came in at 122 lbs each
so; 244 + 41+ 7 = 292 plus say 4 lbs more for hyd fluid 296 lbs
as per these notes bungee gear should be about 66 lbs plus /minus
looks like 230 lbs net increase will be close to the number for me. my
floats are assembled with solid rivets they may be a bit lighter i
don`t know?
my bird weighs 974 according to the weight and balance so the end result
should be 1204. ( or ----1189 depending on the accountant!) 530 lbs
net payload
bob fisher
Sent: Friday, February 27, 2004 8:16 AM
Hi Bob
mounting
Bob Fisher
Post by Bob Fisher » Sat Feb 18, 2012 9:09 am
hi guys i`m just getting ready to make the brackets for the pump, valve
and tank.
does anyone have a photo of a really neat installation including the hose
routings inside the cockpit ?
the smaller the files the better i only have a land line at 24,000 bd
thanks much bob fisher rebel 342 (took my last taildragger flight
today we are mounting next week )
Sent: Thursday, February 26, 2004 12:17 PM
between
post.
for
report.
Regards, Angus
Hi Bruce !
plates ... ;-) :-)
Bobp
it
is,
as
he is
back
same in floats.
Bruce
Post by Drew Dalgleish » Sat Feb 18, 2012 9:09 am
and tank.
between
post.
for
I'm not sure a detachable handle is a good thing. When I want to put my
gear down I want the handle to be where it was when I put the gear up.
Bob Fisher
weights! i just took the gear off my rebel today and weighed it
carefully tonight
mains--- 51 lbs
tail-------9.5 lbs
wheel pants-- 13.5lbs
total 74lbs that was bungee cord suspension and big tires
Sent: Friday, February 27, 2004 9:16 AM
Hi Bob
mounting
