Super Rebel Control Cables
David Qualley
Post by David Qualley » Fri Feb 17, 2012 8:27 pm
I am starting to rig up a few of my control cables now.. My manual
seems to be lacking in detail, I don't know if I am missing parts, can't
find the pages, or if it just doesn't say..
On the end of the cables connected to the Rudder and Elevator horns, do
I use an AN111-4 to form the eye of the cable? Is it installed the same
way as the AN100-4c thimble?
Where do the turnbuckles go on these assemblies? I would guess that
they are at the rudder pedal connection, and the elevator horn at the
rear of Station 8..
klehman
Post by klehman » Fri Feb 17, 2012 8:27 pm
David
Since no SR builders have replied, I can tell you that the standard Rebel manual
is poor in this area as well. But it does show the cable nicopressed around a
AN100C-4 thimble and the AN4-11A elevator horn bolt goes through the thimble.
The control column end is attached to a turnbuckle in the same fashion.
No AN111 bushings are shown even though that seems like a much better idea in
this location. Tony Bingelis says the 111 performs the same function as the 100
and seems to say they are interchangeable.
My current quandary is that I put the floor back as far as the manual specified
and now it looks like a pulley is in order for the upper elevator cable instead
of the specified fair leads. Also my FUS-44 inner cabin corner wraps are 3" too
narrow for the main cabin area. :(
Have you made any provision for cargo tie downs? There is nothing at all shown
in my Rebel manual for ties downs but clearly something is needed.
rear of Station 8..
Lonnie Benson
Post by Lonnie Benson » Fri Feb 17, 2012 8:27 pm
Doug: The Murphy-Rebel List has been expanded to include all models of
Murphy "Metal" You Elite builders can learn alot from reading the archives.
Cc: klehman@albedo.net <klehman@albedo.net>
Date: Monday, October 25, 1999 10:11 AM
Subject: Re: Super Rebel Control Cables
I don't know much about computers yet, so I don't understand how this
showed up on my e-mail as I am building a Elite #665. Hope this get to the
right person.
At 09:00 AM 10/25/99 -0400, you wrote:
David
manual
around a
thimble.
in
the 100
specified
instead
3" too
shown
rear of Station 8..
Doug Martin
greyghost@powernet.net
Doug Martin
Post by Doug Martin » Fri Feb 17, 2012 8:27 pm
right person.
David
manual
the 100
specified
instead
3" too
shown
rear of Station 8..
Doug Martin
