I have a fresh 0235-N2C that is not likely to be run for several months. It
has been mounted on the fuselage for three years. Corrosion protection has
been desiccant plugs, exhaust seals and desiccant filled crankcase vent tube and
the airbox has been sealed off using a bag of desiccant. The crankshaft has
not been turned.
Is it possible to lube the camshaft by spinning the engine with the starter?
Is the camshaft lubricated by splash or with an oil galley?
Norm Wandke
Lycoming Camshaft Lube
Hi Norm !
Several months ?? Sounds like you are really making progress !!
The lobes are lubricated by splash - not sure if spinning the
starter, even without plugs in, would be enough. Might be just as easy to
drop the oil pan & spray the lobes .... just a thought !
----------------------------orig.-------------------
tube andI have a fresh 0235-N2C that is not likely to be run for several months. It
starter?the airbox has been sealed off using a bag of desiccant. The crankshaft has
not been turned.
*-------------------------------------------------------------------------*Is the camshaft lubricated by splash or with an oil galley?
Norm Wandke
Rick Harper
G'day from below Norm ;
(Rick here in Australia) ..... The cam BEARINGS are fed from a
pressurised oil gallery .... but the LOBES (which are the things that
really need the lube - especially after a long while with the engine not
having been turned), are only lubed with what throws off the crank
during rotation.
Chuck Ney (you can look him up on the net .... "Ney Enterprises" from
memory), who used to do manufacturing for Lycoming, has invented a
system of nozzles that give a dedicated squirt of oil to the cam lobes
from the side of the case ..... which has solved many of the problems
with engines with camshaft design errors (H2AD for example)..... BUT
.... ther are SOME people who say this is taking oil pressure away from
the rest of the engine in the process and do not like it !?!?
If it were MY 0-235 .... I'd remove the rocker covers & losses off all
the rockers to the point where they didi not push HARD (or at all) on
the cam lobes ... then, remove all the spark plugs , then spin the
engine with the starter for a good couple of minutes !
This'll lube everything up & not put load on anything !
Replace the plugs, re- adjust the rocker clearances (.010" HOT is the
"norm" for solid lifters - which is what your engine should have) .....
so if you make them .015" to start ..... then run the engine for a few
minutes until it heat soaks, stop it & redo the gaps to .010" you will
be right as rain !
Have fun !
PS 541R .................. is BACK IN THE AIR !!! WOooooo Wooooooo
Wooooooo !!!! :-)
Sent: Tuesday, March 23, 2004 7:53 AM
Subject: Re: Lycoming Camshaft Lube
months. It
protection has
vent tube and
crankshaft has
not been turned.
starter?
Norm Wandke
during rotation.
be right as rain !
Have fun !
Wooooooo !!!! :-)
months. It
protection has
vent tube and
crankshaft has
not been turned.
starter?
Norm Wandke
If an engine is off an airplane, can it be turned upside down to
get oil on the lobes?
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Monday, March 22, 2004 7:43 PM
Hi Norm !
progress !!
be just as easy to
On Monday 22 March 2004 03:53 pm, you wrote:for several months. ItI have a fresh 0235-N2C that is not likely to be runCorrosion protection hashas been mounted on the fuselage for three years.filled crankcase ventbeen desiccant plugs, exhaust seals and desiccant
tube anddesiccant. The crankshaft hasthe airbox has been sealed off using a bag ofengine with thenot been turned.
starter?*------------------------------------------------------Is the camshaft lubricated by splash or with an oil galley?
Norm Wandke
-------------------**------------------------------------------------------To unsubscribe from this list go to:
This is how I suggest to store any engine I have sold. Upside down with a
few quarts of oil in it to keep the cam submerged. Just cap the breather
fitting first! Better yet is an adapted engine stand for car engine overhaul
(that rotate). You can buy these cheap at flea markets/tool clearance
outlets for less than $100. Rotating the engine once in awhile to a
different angle keeps everything coated in oil to avoid rusting.
If the wings aren't on maybe Norm can turn the whole thing upside down for a
day or two!
Sent: Wednesday, March 24, 2004 9:30 AM
Subject: RE: Lycoming Camshaft Lube
day or two!
*-------------------------------------------------------------------------*If an engine is off an airplane, can it be turned upside down to
Patterson
Hi Norm !
progress !!
be just as easy to
Norm Wandke
At 06:30 AM 3/24/2004 -0800, you wrote:
rebuilt and ready to go. He has the engine mounted on a rotisserie and
gives it a couple turns once a month. It's a good thing cuz He's been
working on the tail group for about 10 years. The other thing is to make
sure to use the proper storage oil. I think it tends to creep and keep
everything coated rather than just collecting in the oil sump.
There's a guy near me who has the engine for his Falco project completelyIf an engine is off an airplane, can it be turned upside down to
Newcog
Thanks for all the help with camshaft lube. Since The engine is mounted on
the firewall I liked Rick's (Australia) suggestion to back off the valve
adjusters to unload the cam followers and remove all the spark plugs and spin the
engine with the starter for a couple of minutes. I wonder if I could do this
without the prop installed.
A call to Lycoming a couple of years ago came up with advice to completely
fill the engine with oil (auto oil is fine). A good process but not easy to do
to an engine in the process of being installed
An aside to Bob P: I said months but it might be many months (years?).
Norm W.
Norm W.
