Thanks, I'll check them out. I think you are right about Murphy, they would
have to tack on for their overheads & profits so the price would be higher.
Best I have found so far is a distributer that wanted about $55 for a sheet
but was reluctant to sell just a single sheet. He sells to people like
Murphy
and sells hundreds of sheets at a time.
Any more suggestions out there in case Leavens doesn't pan out??
Dave R.
Bob Patterson wrote:
--You can likely order it from Leavens Aviation, in Mississauga, Ontario,
but I'd bet that it would be cheaper to order it directly from Murphy !!
Hint: you can save shipping costs by having them cut it to a more
convenient size for your use ... Same goes for wing stringers that you
are going to use as stiffeners - much cheaper to ship in 4 foot or 6 foot
lengths.
-----------------------------orig.--------------------------------------
At 09:32 PM 9/15/99 -0300, you wrote:*----------------------------------------------------*Hi All
I am looking for some help in sourcing some 6061-T6 x .020" aluminum
sheet to use in the Rebel building process. Does anyone know where one
can purchase this in single or "few" sheet quantities in Canada?
I am looking to source it in Canada since the brokerage fees (via UPS
etc.) to get it across the border are about 50% of the value of the
material being shipped so if I can find it up here I save a bundle.
Dave R.
David A. Ricker
Nova Scotia
Canada
David A. Ricker P. Eng.
3 Tamarac Drive
Fall River, Nova Scotia
Canada, B2T 1E8
ricker@dbis.ns.ca
Ph. 902-860-0256
