Scott,Just checking out the Odyssey sit. I may go with a PC625, it is 2.2 pounds
lighter than the PC680 and only .75 inch thicker. With an air start seems
this would be more than enough?? The 545 could save another pound.
http://www.odysseybatteries.com/specs.htm
Scott
Moose 174
At this point I think that with the air start of the M-14
the PC545 with it's 12 ah and 12 lbs will be our choice over the
PC680 at 16 ah and 15 lbs. With The B&C aux 8 amp alt. running off the
vac. pump drive I think the 12 ah will be sufficient.
Another Good page for specs:
http://www.batteryweb.com/odyssey.cfm
Good Prices at:
http://www.batterymart.com/battery.mv?c=odyssey
Don B.
