SR elec with V8 Bat Iso
Don Boardman
Post by Don Boardman » Sat Feb 18, 2012 12:04 am
The "Bat Iso" my drawing refers to is the same device I use with my slide in
camper on my truck. It allows me to charge both batteries from the
alternator. It's also supposed to isolate the batteries such that loads on
the camper battery won't drain the truck battery and vice versa.
Hi Mike,
Not sure who's isolator you are using. You might want to check out the link
below. I think they have a set up which does not require that huge battery
selector.
http://www.hellroaring.com/marine.htm
Randy and I are installing Bob's (AeroElectric) All electric on a budget.
50 amp main alt. and the B&C 8 amp aux alt powered of the Vac.pump drive of
the M-14.
Don B.
