Elite Oil Canning Corner Wraps Etc., was: Re: Elite cage riv
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:01 am
Actually should have said right behind the butterfly doubler on the top
section. Have sent Ken a picture! IF anyone else wants "proof" let me know
and I'll send direct to you.
Sent: Tuesday, November 18, 2003 10:55 PM
Subject: Re: Elite Oil Canning Corner Wraps Etc., was: Re: Elite cage rivets
left out
In the middle of the top area. Will see if I can find a picture! Pretty
sure
I have one from Charles D's Mississippi Rebel.
Sent: Tuesday, November 18, 2003 10:29 PM
rivets
left out
Hi Wayne
For the top tail cone corner wraps, can you tell if the buckle starts
along the top rivet line or does the whole thing just start to crumple
in the middle?
thanks
Wayne G. O'Shea wrote:
Know's the time to replace those top two corner wraps Al, before
paint,
as
they will start to buldge after a couple rough strips and will buckle
after
a good hard landing.
Then again if you are sticking with the tricycle gear configuration
they
won't be an issue, as the load will try to stretch them in a hard
landing
instead of compressing them in the case of a tailwheel configured
aircraft!
