Elite Oil Canning Corner Wraps Etc., was: Re: Elite cage riv
klehman
Post by klehman » Sat Feb 18, 2012 12:01 am
Hi Wayne
For the top tail cone corner wraps, can you tell if the buckle starts
along the top rivet line or does the whole thing just start to crumple
in the middle?
thanks
Wayne G. O'Shea wrote:
Know's the time to replace those top two corner wraps Al, before paint, as
they will start to buldge after a couple rough strips and will buckle after
a good hard landing.
Then again if you are sticking with the tricycle gear configuration they
won't be an issue, as the load will try to stretch them in a hard landing
instead of compressing them in the case of a tailwheel configured aircraft!
