Moose Cabin Heat Box
Al & Deb Paxhia
Post by Al & Deb Paxhia » Fri Feb 17, 2012 11:54 pm
I have a separate heat boxes for defrost and cabin heat. Fresh air comes
from two separate side vents just below the motor mounts. The heat is not a
problem now that the interior is installed. Prior to installing the interior
and insulation it was very cold inside with heat and defrost going full
blast ( -10F outside +10F inside).
Al
Moose, N526AP
Sent: Saturday, October 18, 2003 11:29 AM
Subject: Moose Cabin Heat Box
Hey Guys,
1) What have you guys that are flying installed for cabin heat ? We have
M-14 with dual heat muffs.
2)Any consideration in the cabin for rear passenger heat and/or defrost ?
3)Separate hot air and separate cool fresh air versus a box that mixes.
Any
comments ?
4) Advise any fresh air venting hardware that has been found to work well.
Thanks for the feedback in advance.
Randy Bowers Moose 130
RJBWoodman
Post by RJBWoodman » Fri Feb 17, 2012 11:54 pm
Hey Guys,
1) What have you guys that are flying installed for cabin heat ? We have the
3)Separate hot air and separate cool fresh air versus a box that mixes. Any
comments ?
Rhodes
Post by Rhodes » Fri Feb 17, 2012 11:58 pm
Randy
We put a mixer box in Ron Kakeldey's. It takes fresh air from 2 flanges
between the cylinders and the heat comes off the right muff. It has one 2"
hole coming into the cabin and it will cook you out of the front seats. The
left muff is connected to the airbox for carb heat which is overkill as
alternate air from near the engine is enough I have heard.
I too have dual heat muffs and may use both for heat as I do a lot of winter
flying.
Too keep it simple in the winter you can connect a hose to the firewall to
take half of the air to the back seats. I used a heavier non-aircraft hose
(blue) in my 185 which laid on the floor and it lasted many years.
We also put a couple plastic vents in the bottom front corner of his front
windows- the kind that has a little black knob and four screws to hold them.
They work good and will close off completely but are a little ugly.
If you come up with a better way to direct air to the back let me know.
My # 907-345-5172 or Ron 907-248-5140
Steve Rhodes
Moose 173
rhodes5@gci.net
Sent: Saturday, October 18, 2003 09:29
Hey Guys,
Any
comments ?
