venting
venting
Post by Walter Klatt » Fri Feb 17, 2012 11:12 pm
I've got cross venting to my tanks, AND I have a ram
air tube on each cap, with all other cap vents sealed
off. I do remember some fuel flow problems on the early
Rebels, so I thought I took all the steps I could think
of to avoid this type of problem. The only other thing
might be a fuel pump.
Murray and Carol Cherkas
Sent: Monday, June 30, 2003 10:14 PM
Subject: venting
Hello Walter
I'm glad your engine outs had a happy
ending.Not flying yet so haven't had
this problem.
Please clear this up for me as I am close to
venting my tanks. You did not
cross vent the tanks but installed forward
facing ram air tubes on each
filler cap.Would you do this again?
Thanks for the help
Murray
http://www.dcsol.com:81/public/code/html-subs
cribe.wcx
Archives located at
venting
Post by Murray and Carol Cherkas » Fri Feb 17, 2012 11:12 pm
Hello Walter
I'm glad your engine outs had a happy ending.Not flying yet so haven't had
this problem.
Please clear this up for me as I am close to venting my tanks. You did not
cross vent the tanks but installed forward facing ram air tubes on each
Thanks for the help
Murray
venting
Thanks Walter:
This seems like a good thing. Cross vent and install ram air tubes on each
filler cap instead of one vent in wing root fairing.
Hope you solve your dilemma.
Thanks again
Murray
Sent: Monday, June 30, 2003 9:30 PM
Subject: RE: venting
Subject: venting
Hello Walter
this problem.
Thanks for the help
Murray
cribe.wcx
Archives located at
venting
Hi, Alister. I do have the aluminium shroud around the
gascolator, but don't have the cooling duct from the
baffles. Because I'm challenged in keeping my CHT's
down, I don't think I can afford more loss of air from
the cylinders. I do have little cooling ducts on my
magneto's but I don't think that costs me much. Thanks
for your suggestion.
yeom
Sent: Tuesday, July 01, 2003 12:21 AM
Subject: Re: venting
Just a thought Walter, I built an aluminium
shroud around the gasculator on
my rebel and ducted cold air from the back
of the cooling baffles to it.
saw it done on a piper cherokee once)
If you are using Mogas would perhaps that be an idea.
Alister
Sent: Tuesday, July 01, 2003 4:29 PM
have a ram
vents sealed
on the early
I could think
other thing
Subject: venting
Hello Walter
this problem.
Thanks for the help
Murray
cribe.wcx
Archives located at
cribe.wcx
Archives located at
Archives located at
venting
Post by Murray and Carol Cherkas » Fri Feb 17, 2012 11:15 pm
A little off the subject but a thought.
I talked to Brian at MAM re: cooling. When I get to floats he suggested that
I get cooling air for the oil cooler from a scoop rather than from a hole in
the baffle.
Murray
Sent: Tuesday, July 01, 2003 7:01 AM
yeom
Alister
have a ram
vents sealed
on the early
I could think
other thing
Subject: venting
Hello Walter
this problem.
Thanks for the help
Murray
cribe.wcx
Archives located at
cribe.wcx
Archives located at
Archives located at
venting
Post by Walter Klatt » Fri Feb 17, 2012 11:15 pm
I would agree with that suggestion. In winter I have to
tape off part of the oil cooler opening, which provides
more cooling to my cylinders, but when I don't need it.
Then in the summer I open the oil cooler again and lose
cooling on my cylinders right when I need it the most.
Not sure how you would catch the air for the cooler
outside the baffles, maybe some kind of NACA inlet on
the side.
I forgot which cowl you had, Murray. If it's the old
style aluminium one, it shouldn't matter from what I
have heard on this list. It's just the fibreglass cowl
that has these cooling problems because it is so tight
on top and in the front where the inlets are.
Sent: Tuesday, July 01, 2003 10:06 PM
the baffle.
Murray
around the
of air from
much. Thanks
yeom
be an idea.
Alister
have a ram
vents sealed
on the early
I could think
other thing
cribe.wcx
Archives located at
cribe.wcx
Archives located at
Archives located at
Archives located at
Archives located at
yeom
venting
Post by yeom » Fri Feb 17, 2012 11:15 pm
Just a thought Walter, I built an aluminium shroud around the gasculator on
my rebel and ducted cold air from the back of the cooling baffles to it.
Alister
Subject: venting
Hello Walter
this problem.
Thanks for the help
Murray
cribe.wcx
Archives located at
